Páginas (2): 1 2
envira   27 Sep, 2011, 12:36 pm
not working 0.9 after i create album it is not showing any albums in profile or in user cp.
i think you should recheck the plugin.
Omar G.   27 Sep, 2011, 1:42 pm
(27 Sep, 2011, 12:36 pm)envira escribió: not working 0.9 after i create album it is not showing any albums in profile or in user cp.
Just add the variable to the member_profile template.
[Imagen: signature.png]
envira   27 Sep, 2011, 2:16 pm
I reinstalled the plugin by reuploading all the files.
I can see the albums in user cp,and after i create the album,it is saying that album is created and coming to usercp.
I cant see any albums in usercp or profile.
i think the plugin is defective.
is there a working demo ????
Cluster   27 Sep, 2011, 4:06 pm
@envira for more support on english you can write your problem on the international support forum and need set your forum information on this path
envira   28 Sep, 2011, 12:44 am
i no consigue lo que usted dijo. el plugin no funcionaba en mi foro., el problema es
Puedo volver a instalar el plugin de volver a subir todos los archivos.
Puedo ver los álbumes en Panel de Control, y después de crear el disco, es decir que el álbum se crea y se viene a Opciones de Búsqueda.
No puedo ver los álbumes en Opciones de Búsqueda o perfil.
Creo que el plugin está defectuoso.
hay una demostración de trabajo??
Omar G.   28 Sep, 2011, 11:31 am
envira   20 Oct, 2011, 12:37 pm
envira   2 Nov, 2011, 10:57 am
#8
can anyone answer me ????
this plugin is not working on my forum,i have posted in all sections.
What variable is to be added to member_profile...
can u explain.
Thank you
Cluster   2 Nov, 2011, 7:08 pm
#9
You can contact directly whit the plugin author
[Imagen: postbit_pm.gif]
Omar G.   3 Nov, 2011, 6:15 am
#10
Cita:What variable is to be added to member_profile...
You can check the plugin file to search the variable you need.
Páginas (2): 1 2
