Resulta que e instalado el plugins Board Messages - 2.0.0 y no me funciona, cuando le doy a "instalar y activar" me salta un mensaje:
SQL Error:
1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Type=MyISAM' at line 8
Query:
CREATE TABLE mybb_board_messages ( mid
int(10) unsigned NOT NULL auto_increment, message
text NOT NULL, class
varchar(255) NOT NULL, global
tinyint(1) NOT NULL default '1', enabled
tinyint(1) NOT NULL default '0', PRIMARY KEY (mid) ) Type=MyISAM;
TAMBIEN ME PASA CON EL PLUGINS Thanks - 3.9.1
SQL Error:
1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 't delete table','onoff','1','1','24')' at line 3
Query:
INSERT INTO mybb_settings (name
,title
,description
,optionscode
,value
,disporder
,gid
) VALUES ('thx_active','Activate/Deactivate this plugin','Activate or deactivate plugin but doesn't delete table','onoff','1','1','24')
Espero solucionarlo, Gracias de antemano.
