Foro: http://neverfall.co.cc
version: 1.6
theme: 1 Apart
Problema: entren al foro y mirenlo. El footer no existe, es como otro index
Ve a la plantilla footer y pon el codigo correcto.
Pon este si quieres;
Plantilla > FOOTER
Quote:<div id="debug"><debugstuff></div>
<div id="footer">
<div class="upper">
<div class="wrapper">
{$lang_select}
<ul class="menu bottom_links">
<li><a href="{$mybb->settings['contactlink']}">{$lang->bottomlinks_contactus}</a></li>
<li><a href="{$mybb->settings['homeurl']}">{$mybb->settings['homename']}</a></li>
<li><a href="#top">{$lang->bottomlinks_returntop}</a></li>
<li><a href="<archive_url>">{$lang->bottomlinks_litemode}</a></li>
<li><a href="{$mybb->settings['bburl']}/misc.php?action=syndication">{$lang->bottomlinks_syndication}</a></li>
<li><a href="{$mybb->settings['bburl']}/misc.php?action=help" class="help">{$lang->toplinks_help}</a></li>
</ul>
<div class="lower">
<span id="current_time">{$lang->welcome_current_time}</span>
<span id="copyright">
<!-- MyBB is free software developed and maintained by a volunteer community.
It would be much appreciated by the MyBB Group if you left the full copyright and "powered by" notice intact,
to show your support for MyBB. If you choose to remove or modify the copyright below,
you may be refused support on the MyBB Community Forums.
This is free software, support us and we'll support you. -->
{$lang->powered_by} <a href="http://www.mybboard.net" target="_blank">MyBB{$mybbversion}</a>, &copy; 2002-{$copy_year} <a href="http://www.mybboard.net" target="_blank">MyBB Group</a> Theme editado por <b>Neverfall Staff.</b>
<!-- End powered by --> </span>
Plantilla > FOOTER_LENGUAJESELECT
Quote:<div class="language">
<form method="{$lang_redirect_url['form_method']}" action="{$lang_redirect_url['location']}" id="lang_select">
{$lang_redirect_url['form_html']}
<select name="language" onchange="MyBB.changeLanguage();">
<optgroup label="{$lang->select_language}">
{$lang_options}
</optgroup>
</select>
{$gobutton}
</form>
No funciona, he hecho lo que dices y nada
Lo que creo que te pasa es que tienes la cabecera repetida.
Vete a las plantillas > Cabecera > header
Mira allí si tienes el código repetido.
El header está perfecto y no hay nada repetido
Pues el header es justo la parte que está repetida :S
Pásame tu plantilla ,del header-cabecera y la de pie-footer y yo te lo arreglo WinkBig Grin
HEADER
Quote:<div id="container">
<a name="top" id="top"></a>
<div id="header">
<div id="logo">
<center><a href="{$mybb->settings['bburl']}/index.php"><img src="{$theme['logo']}" alt="{$mybb->settings['bbname']}" title="{$mybb->settings['bbname']}" /></a></center>
<div id="panel">
<div class="upper"><!-- This div(class="upper") is closed in the header_welcomeblock_member and header_welcomeblock_guest templates -->
<ul class="menu top_links">
<li><a href="{$mybb->settings['bburl']}/index.php" class="index">Índice</a></li>
<li><a href="{$mybb->settings['bburl']}/search.php" class="search">{$lang->toplinks_search}</a></li>
<li><a href="{$mybb->settings['bburl']}/memberlist.php" class="memberlist">{$lang->toplinks_memberlist}</a></li>
<li><a href="{$mybb->settings['bburl']}/calendar.php" class="calendar">{$lang->toplinks_calendar}</a></li>
</ul>
{$welcomeblock}
<div id="content">
{$pm_notice}
{$bannedwarning}{$imgflotante}
{$bbclosedwarning}
{$unreadreports}
{$pending_joinrequests}
<navigation>
<br />
<center>
<table class="tborder" cellspacing="1" cellpadding="4" border="0">
<td class="thead"><strong>Afiliados</strong></td></tr>
<tr><td class="trow1">
<marquee> <a href="http://comunity-act.foromx.net" target="_blank"><img src="http://i821.photobucket.com/albums/zz137/Ryna156/bannerca7.gif" width="88" height="31"></a><a href="http://troyanosyvirus.com.ar"><img src="http://img7.imageshack.us/img7/2012/logotyv88x312.gif" width="88" height="31"></a><a href="http://www.tuforoparawebmasters.com"><img src="http://img225.imageshack.us/img225/1237/minicenter.gif" width="88" height="31"></a><a href="http://yoshifansclub.com"><img src="http://img17.imageshack.us/img17/5656/sinttulo1gl7.gif" width="88" height="31"></a><a href="http://neverfall.foroactivo.com"><img src="http://img840.imageshack.us/img840/8772/gfx.gif" width="88" height="31"></a> </marquee>
</td></tr></table></center><br />
FOOTER
<div id="footer">
<div class="upper">
{$lang_select}
</ul>
<div class="lower">
Alguna solucion?, mi foro parece una hoja mal imprimida xDDD
Sube de nuevo el XML y modificalo de nuevo ;S
O debe ser un error de una plantilla o del global css
