[General] How to Fix Lag When Playing Honor of Kings Overseas
If you're living or studying abroad, you've probably experienced frustrating lag while playing Honor of Kings (Chinese Server). High ping, unstable connections, and frequent delays can make team fights difficult and affect your overall gaming experience.
The good news is that most of these issues can be improved with a few simple steps. Here's how to reduce lag and enjoy smoother gameplay.
Why Does Honor of Kings Lag Overseas?
The Chinese servers are hosted in mainland China. When you're connecting from countries like the United States, Canada, Australia, the UK, or Europe, your game data has to travel a much longer distance. This often leads to:
How to Reduce Lag While Playing Abroad
1. Use a Stable Wired or Wi-Fi Connection
Avoid public Wi-Fi whenever possible. A reliable home network or wired Ethernet connection usually provides lower latency and fewer connection drops.
2. Close Background Applications
Streaming videos, downloading files, or running cloud backups while gaming can consume bandwidth and increase network delay. Closing unnecessary applications helps prioritize your game traffic.
3. Connect to the Nearest Network Node
If you're using a gaming network optimization service, choose the node closest to your physical location. This can help reduce unnecessary routing and improve connection stability.
4. Restart Your Router
Sometimes network congestion builds up over time. Restarting your router can refresh your connection and improve performance.
5. Use a Dedicated China Game Accelerator
A dedicated accelerator with optimized routes to mainland China can significantly reduce ping and packet loss. Many overseas players choose tools such as speedx中国线路加速器 to improve network stability when accessing Chinese game servers. Choosing an accelerator with intelligent routing and multiple China nodes often delivers better results than a standard VPN.
Additional Tips for Better Gameplay
Experiencing lag while playing Honor of Kings overseas is common, but it doesn't have to ruin your matches. By optimizing your local network, reducing background traffic, and using a reliable game accelerator like speedx Low latency China VPN, you can enjoy lower latency and a much smoother gaming experience on the Chinese servers.
Whether you're an international student, overseas Chinese, or traveling abroad, a stable connection makes every match more enjoyable.
- High latency (100ms–300ms or more)
- Packet loss
- Unstable network routing
- Delayed skill casting and movement
- Connect to a 5GHz Wi-Fi network if available.
- Avoid downloading large files during gameplay.
- Keep the game updated to the latest version.
- Restart the game after switching networks.
- Play during off-peak hours if your local network becomes congested in the evening.
