Siguiendo éste tema, prefiero preguntar aquí.
Lo dejé aparcado y ahora quiero volver a intentar ponerlo.
Tengo varías dudas:
Cuando hay que modificar el global.css, se modifica el de estilos dentro del ACP o me tengo que meter con Fillezilla y modificar el global.php?¿
Es esto?¿
Lo más que conseguí fue esto:
Tengo varías dudas:
Es esto?¿
Código PHP:
/* http://www.menucool.com */
#sliderFrame {position:relative;width:700px;margin: 0 auto;}
#slider {
width:700px;height:306px;/* Make it the same size as your images */
background:#fff url(loading.gif) no-repeat 50% 50%;
position:relative;
margin:0 auto; /*this makes the image slider center-aligned. Remove this line if you want to align the whole slider to the left side*/
box-shadow: 0px 1px 5px #999999;
#slider img, #slider>b, #slider a>b{
position:absolute;
border:none;
display:none;
#slider>a {display:none;}
/* the link style (if an image is wrapped in a link) */
#slider a.imgLink {
z-index:2;
position:absolute;
top:0px;left:0px;border:0;padding:0;margin:0;
width:100%;height:100%;
#slider a.video {
background:transparent url(video.png) no-repeat 50% 50%;
/* Caption styles */
div.mc-caption-bg, div.mc-caption-bg2 {
position:absolute;
width:100%;
height:auto;
padding:0;
left:0px; /*if the caption needs to be aligned from right, specify by right instead of left. i.e. right:20px;*/
bottom:0px;/*if the caption needs to be aligned from top, specify by top instead of bottom. i.e. top:150px;*/
z-index:3;
overflow:hidden;
font-size: 0;
div.mc-caption-bg {
background-color:black;
background:none;
div.mc-caption {
font: bold 14px/20px Arial;
color:#EEE;
z-index:4;
padding:10px 0;/*Adding a padding-left or padding-right here will make the caption area wider than its background. Sometimes you may need to define its width again here to keep it the same width as its background area (div.mc-caption-bg).*/
text-align:center;
background:none;
div.mc-caption a {
color:#FB0;
div.mc-caption a:hover {
color:#DA0;
/* ------ built-in navigation bullets wrapper ------*/
div.navBulletsWrapper {
top:320px; left:280px; /* Its position is relative to the #slider */
width:150px;
background:none;
padding-left:20px;
position:relative;
z-index:5;
cursor:pointer;
/* each bullet */
div.navBulletsWrapper div
width:11px; height:11px;
background:transparent url(bullet.png) no-repeat 0 0;
float:left;overflow:hidden;vertical-align:middle;cursor:pointer;
margin-right:11px;/* distance between each bullet*/
_position:relative;/*IE6 hack*/
div.navBulletsWrapper div.active {background-position:0 -11px;}
/* --------- Others ------- */
#slider
transform: translate3d(0,0,0);
-ms-transform:translate3d(0,0,0);
-moz-transform:translate3d(0,0,0);
-o-transform:translate3d(0,0,0);
.loading
width:100%; height:100%;
background:transparent url(loading.gif) no-repeat 50% 50%;
filter: alpha(opacity=60);
opacity:0.6;
position:absolute;
left:0;
top:0;
z-index:9;
Última modificación: 31 Mar, 2014, 5:09 am por storm.
