[Ayuda] Dos problemas SQL sin saber por que
Url www.xtremereaxion.comxa.com/foro
Vercion 1.4.11
Prolema :
Tengo 2 prolemas y no se por qe son avece se cae el foro y salta :
SQL Error:
1028 - Sort aborted
Query:
SELECT f.*, fr.dateline AS lastread FROM mybb_forums f LEFT JOIN mybb_forumsread fr ON (fr.fid=f.fid AND fr.uid='44') WHERE f.active != 0 ORDER BY pid, disporder
se cae el foro y por un ratito no anda
Prolema2: cuando kiero editar un rango (administrador,super moderador,moderador,etc) Salta :
SQL Error:
1054 - Unknown column 'cansendcomments' in 'field list'
Query:
UPDATE mybb_usergroups SET
Vercion 1.4.11
Prolema :
SQL Error:
1028 - Sort aborted
Query:
SQL Error:
Query:
type='1', title='Administradores', description='El grupo en el que están todos los administradores.', namestyle='{username}', usertitle='Administrador', stars='7', starimage='images/star.gif', image='/images/clean-group/english/team-administrator.gif', isbannedgroup='0', canview='1', canviewthreads='1', canviewprofiles='1', candlattachments='1', canpostthreads='1', canpostreplys='1', canpostattachments='1', canratethreads='1', caneditposts='1', candeleteposts='1', candeletethreads='1', caneditattachments='1', canpostpolls='1', canvotepolls='1', canusepms='1', cansendpms='1', cantrackpms='1', candenypmreceipts='1', pmquota='0', maxpmrecipients='0', cansendemail='1', maxemails='0', canviewmemberlist='1', canviewcalendar='1', canaddevents='1', canbypasseventmod='1', canmoderateevents='1', canviewonline='1', canviewwolinvis='1', canviewonlineips='1', cancp='1', issupermod='1', cansearch='1', canusercp='1', canuploadavatars='1', canchangename='1', showforumteam='1', usereputationsystem='1', cangivereputations='1', reputationpower='2', maxreputationsday='0', attachquota='0', cancustomtitle='1', canwarnusers='1', canreceivewarnings='1', maxwarningsday='0', canmodcp='1', canmanagecomments='1', cansendcomments='', caneditselfcomments='', candeleteselfcomments='', myplaza_rate='1', myplaza_income_rate='1' WHERE gid='4'
Hmm, puedes entrar al Panel Admin??
Intenta reparar todas las tablas que no estén corruptas, analizadas u optimizadas en:
Panel Admin >> Mantenimiento >> Optimizar BD
Inicia para que optimize todas las tablas de la base de datos.
Si no funciona, entra en:
Mantenimiento >> Conversión UTF-8
Cualquier table que no esté convertida, da click en "Convertir ahora", o en convertir todas de una buena vez.
Si no te funciona.... no lo se. D:
Esa es mi sugerencia. :zeh:
IMPORTANTE: Para no dejarte peor el foro es mejor que hagas una copia de seguridad de la base de datos antes de hacer los cambios.
Si no puedes, intenta hacerlo desde PHPMyAdmin.
noooooooooooooooooooooooo
Atencion Lee Primero Antes de Hacer Las Cosas
Angel La Conversion No Tiene nada Que Ver Pues solo Transforma Idiomas Erroneos (Ejemplo La ñ y los ´)
Esa Conversion Borra TODO En Los Posts A partir de LAs ñ y ascentos
osea ejemplo:
post.- Hola Como Estas espero te la pases genial Ñoño
la conversion te lo dejara en
Y es irreversible
el primer error es un error comun cuando mysql tarda en cargar automaticamente aborta la operacion por seguridad (Pasa en hostings con servicio mysql lento)
el segundo es porque borraste esas tablas
te recomiendo reinstalar myplaza o ejecutar el upgrade
osea ejemplo:
Y es irreversible
PERDON QE NO RESPONDI NO ESTABA , ESTABA DE VACACIONES YA SE QE PASO BASTANTE TIEMPO Pero... reinstalar todo el mybb y perder los posts y todo ? nah dejate de joder... ejecutar el upgrade? ya tengo la 1.4.11 o como sea reparar la tablas decime como... qe se puedo aver "roto"
tanto post y no ayuda...
mira amigo es simple.
ve al phpMyadmin
vas a tu base de datos en el foro.
va a la pestaña SQL
y donde este para introducir el texto pones esto
y le das en ejecutar o algo asi y listo
ve al phpMyadmin
va a la pestaña SQL
type='1', title='Administradores', description='El grupo en el que están todos los administradores.', namestyle='{username}', usertitle='Administrador', stars='7', starimage='images/star.gif', image='/images/clean-group/english/team-administrator.gif', isbannedgroup='0', canview='1', canviewthreads='1', canviewprofiles='1', candlattachments='1', canpostthreads='1', canpostreplys='1', canpostattachments='1', canratethreads='1', caneditposts='1', candeleteposts='1', candeletethreads='1', caneditattachments='1', canpostpolls='1', canvotepolls='1', canusepms='1', cansendpms='1', cantrackpms='1', candenypmreceipts='1', pmquota='0', maxpmrecipients='0', cansendemail='1', maxemails='0', canviewmemberlist='1', canviewcalendar='1', canaddevents='1', canbypasseventmod='1', canmoderateevents='1', canviewonline='1', canviewwolinvis='1', canviewonlineips='1', cancp='1', issupermod='1', cansearch='1', canusercp='1', canuploadavatars='1', canchangename='1', showforumteam='1', usereputationsystem='1', cangivereputations='1', reputationpower='2', maxreputationsday='0', attachquota='0', cancustomtitle='1', canwarnusers='1', canreceivewarnings='1', maxwarningsday='0', canmodcp='1', canmanagecomments='1', cansendcomments='', caneditselfcomments='', candeleteselfcomments='', myplaza_rate='1', myplaza_income_rate='1' WHERE gid='4'y le das en ejecutar o algo asi y listo
Ehhhm no entendi un pomo va entendi pero no encuentro nada cn esos nombres :S phpmyadmin te referis al panel de admin pero dsp no tengo ni la mas palida idea... si podes poner un pokito de ganas aunqesea Gracias. FoKo
PHPMyamin no es el panel admin...
Panel admin es panel admin, y PHPMyadmin es otra cosa
Vas a tu host, ha phpmyadmin
Bueno amigo te dejo una imagen con las instrucciones cuando entres al PHPMyAdmin
![[Image: attachment.php?aid=253]](http://www.mybb-es.com/attachment.php?aid=253)
Despues de tanto tiempo y sigo cn el prolema...
Mira sigo sin solucion puse todo lo qe me dijieron el texto ese y cuando pongo "Go" (despues de introducir el codigo largo) y me salta error
Error
SQL query:
"Aca sale todo el codigo grande"
y despues del code
MySQL said: Documentation
#1054 - Unknown column 'cansendcomments' in 'field list'
Bueno Gracias por intentar ayudarme espero su respuesta
Error
SQL query:
y despues del code
no entiendo bien pero
intenta reparar las tablas en la parte baja hay una caja de seleccion y ahi selecciona reparar tablas
