[Ayuda]  con MyForumIcons
Tengo problemas con este pluguin (MyForumIcons) ya lo tengo instalado pero no se donde tengo que pegar o remover para que funcione :-/ This will all...
Tengo problemas con este pluguin (MyForumIcons) ya lo tengo instalado pero no se donde tengo que pegar o remover para que funcione  Undecided
This will allow you to create custom icons for your forums.
You can specify a path to your forum's custom icon by going to the ACP => Forum Management => Edit Forum.
When installed, it will alter the forums table to add a column called myforumicon, which will be used for the custom icon of your forum.
When activated, modifications to your forumbit_depth2_forum template will be made. It uses the following code to replace templates:
function myforumicons_activate()
 require_once MYBB_ROOT."inc/adminfunctions_templates.php";
 find_replace_templatesets("forumbit_depth2_forum", "#".preg_quote("id=\"mark_read_{\$forum['fid']}\"></span>")."#i", "id=\"mark_read_{\$forum['fid']}\" {\$forum['myforumicon_override']}></span>{\$forum['myforumicon']}");
Esta es de mi plantilla forumbit_depth2_forum
<td class="{$bgcolor}" align="center" valign="middle" width="1"><div class="forum_status forum_{$lightbulb['folder']} ajax_mark_read" title="{$lightbulb['altonoff']}" id="mark_read_{$forum['fid']}"><i class="fa fa-circle-o"></i></div></td>
<td class="{$bgcolor}" valign="middle">
  <strong><a href="{$forum_url}"><span class="threadtext">{$forum['name']}</span></a></strong><br />{$forum_viewers_text} {$forum['description']} {$subforums}</td>
<td class="{$bgcolor}" valign="middle" align="left" width="23%" style="white-space: nowrap">{$lastpost}</td>
  <td class="{$bgcolor}" valign="middle" align="center" width="9%" style="white-space: nowrap">
    <span class="threadtext">Topics </span><br />{$threads}{$unapproved['unapproved_threads']}</td>
  <span class="threadtext">Replies </span><br />{$posts}{$unapproved['unapproved_posts']}</td>
¿Y no has pensado en hacerlo con FontAwesome? Es mejor a la larga, menos carga para el servidor, miles de imagenes, fácil de hacer. No sé, digo yo.
Ese codigo PHP esta buscando
id="mark_read_{$forum['fid']}"></span>
Pero en tu plantilla no esta.
Deja tu plantilla  forumbit_depth2_forum asi:
<td class="{$bgcolor}" align="center" valign="middle">
   {$forum['myforumicon_override']}
   {$forum['myforumicon']}
Y deberia funcionar.
me sale esto style="display: none;" u.u me rindo, provare con lo que dice andres :p
(20 Apr, 2015, 4:03 am)AndresXZ09 escribió: ¿Y no has pensado en hacerlo con FontAwesome? Es mejor a la larga, menos carga para el servidor, miles de imagenes, fácil de hacer. No sé, digo yo.
Hola! podrías retomar el caso? a mi tambien me tira el mismo error!
Ya casi estamos.. saludos!
Última modificación: 14 Jul, 2015, 10:21 pm por adukeN.
(20 Apr, 2015, 8:10 am)Jazo16 escribió: me sale esto style="display: none;" u.u me rindo, provare con lo que dice andres :p
La lectura del MyForumicon es esta linea unicamente
Probá con este code.
ASí deberia andarte..
BitLiberal AndresXZ09 adukeN
