Importante:
¿Como pedir soporte? (Marzo 18, 2015)
[Ayuda] Ayuda con Postbit acenavy 1.6x Recuadrar
Quisiera recuadrar eso por favor, Cluster :vueltas: Aqui te dejo el codigo que tengo en el postbit_classic: {$ignore_bit} <table border="0" cellsp...
[Imagen: recuadrar.png]
{$ignore_bit}
<table border="0" cellspacing="{$theme['borderwidth']}" cellpadding="{$theme['tablespace']}" class="tborder" style="{$post_extra_style} {$post_visibility}" id="post_{$post['pid']}">
		<td class="threadtcat" width="18%" valign="top" style="white-space: nowrap; text-align: center;"><a name="pid{$post['pid']}" id="pid{$post['pid']}"></a>{$post['onlinestatus']} <strong><span class="largetext">{$post['profilelink']}</span></strong>
		<td class="threadtcat" valign="middle" style="white-space: nowrap;">{$post['posturl']}<span class="smalltext"><strong>{$post['icon']}{$post['subject']} {$post['subject_extra']}</strong></span><br /></div>
		<td class="{$altbg}" width="15%" valign="top" style="white-space: nowrap; text-align: center;">
			<span class="rankname rankname_green originalcursor">{$post['usertitle']}</span><br />
			{$post['userstars']}<br />
			{$post['groupimage']}
			{$post['useravatar']}<br /><br />
			{$post['user_details']}
                        {$post['points_pip']}
                        {$post['levelbar']}
<br />
		</span>
		<div align="center"><span class="smalltext">{$post['button_email']}{$post['button_pm']}{$post['button_www']}{$post['button_find']}{$post['button_rep']}</span></div><br /><br /><br />
	<td class="{$altbg}" valign="top">
		<table width="100%">
			<tr><td>
			<div id="pid_{$post['pid']}" class="post_body">
				{$post['message']}
			{$post['attachments']}
			{$post['signature']}
			<div style="text-align: right; vertical-align: bottom;" id="post_meta_{$post['pid']}">
				<div id="edited_by_{$post['pid']}">{$post['editedmsg']}</div>
				{$post['iplogged']}
		</td></tr>
	</table>
	<td class="{$altbg}" style="white-space: nowrap; text-align: center; vertical-align: middle;"><span class="smalltext">{$post['postdate']} {$post['posttime']}</span></td>
	<td class="{$altbg}" style="vertical-align: middle;">
		<table width="100%" border="0" cellpadding="0" cellspacing="0">
			<tr valign="bottom">
				<td align="right">{$post['button_edit']}{$post['button_quickdelete']}{$post['button_quote']}{$post['button_multiquote']}{$post['button_report']}{$post['button_warn']}{$post['button_reply_pm']}{$post['button_replyall_pm']}{$post['button_forward_pm']}{$post['button_delete_pm']}</td>
		</table>
</tr><!-- PointsInPosts -->{$post['pip_classic']}<!-- /PointsInPosts -->
</table>{$post['adsaf']}
Otra ayuda que si tienes tiempo seria como le pongo un botón igual al que trae el theme pero para dar gracias, Saludos Smile
Tema anterior Tema siguiente
lo mas seguro es que ese tiene su propio class. entra en su class y agregale las propiedades
hago coloco el mismo code que usan las de userdetails y se me descuadra ... u.u Sad
como lo estas colocando?
Como lo indique en el codigo que postee asi lo pongo y asi queda [Imagen: recuadrar.png]
Necesito que se recuerdre el gracias, puntos y barras tambien como hago?
Disculpa por hacer doble post, obviamente no queda con ese marquito rojo ese lo puse yo con paint para que veas que es lo que quiero recuadrar.
Última modificación: February 17, 2012, 7:38 pm por ServersWz.
{$ignore_bit}
                        <div class="postbit-box">{$post['points_pip']}
                        {$post['levelbar']}</div>
<br />
        </span>
            <tr><td>
                {$post['message']}
                {$post['iplogged']}
        </td></tr>
    </table>
        </table>
Wink prueba con ese
Graciias amigo, y gracias a ese codigo recuadre el gracias con este codigo:
<div class="postbit-box">{$lang->thx_thank}{$post['thank_count']}<br />
                        {$post['thanked_count']}</div>
Solo hay que ir a Plantillas globales -> post_thanks_count y reemplazen ese codigo por que el que les indico:
Muchas gracias pueden cerrar Smile
cierro tema
Colaboradores: zahipro , Lex , DARKNESSDH , Cluster
