A Wrench in the Works is a short Arc Raiders quest, but it asks a useful question: can you read Spaceport well enough to find objectives that are not placed in obvious landmarks? Players searching for ARC Raiders BluePrints may be focused on broader progression, yet this mission offers something more immediate: a practical lesson in routes, overlooked interiors, and safe positioning. You must inspect a bus near the western gate, then recover sabotage supplies at the Water Towers. The objectives are simple; the route between them deserves more attention.
What the Quest Actually Requires
Celeste offers A Wrench in the Works after Safe Harbor. The investigation points toward organized resistance among Spaceport workers, but the useful details are easy to miss if you follow the markers without checking your surroundings.
The first objective is inside a bus near the western gate. Look on the wall behind the driver's seat to find the notes. The bus is positioned along the western road between the Departure Building and Arrival Building, on the route leading toward the Water Towers. It is not a major building with a prominent silhouette, so players who search only around the largest structures can run past it.
The second objective is at the northernmost Water Tower in the northwestern part of Spaceport. Climb the scrap-metal route to the narrow ledge, then turn your view back toward the approach. The supply container is placed behind that approach point rather than directly in front of you.
Why the Route Matters More Than the Markers
This quest is a compact navigation test. The western gate teaches you to inspect transport objects and road edges, while the Water Towers teach you to check vertical spaces from more than one angle. That pattern is valuable in later runs because Spaceport often rewards recognition instead of raw speed.
The bus stage usually feels safer because it sits near familiar travel lanes and large buildings. The tower stage changes the pressure. You move toward a more exposed area, climb a narrow route, and must pause to locate the supplies. Rushing can turn a quick mission into an unnecessary fight or a difficult retreat.
A Practical Run Plan
Use the following approach if you want to finish the quest without wasting time searching every structure.
◆ Check the western road and nearby terrain before entering the bus.
◆ Search behind the driver's seat rather than scanning the bus at random.
◆ After reading the notes, choose a northern route with cover instead of automatically taking the shortest line.
◆ Confirm that you are climbing the northernmost tower before committing to the scrap-metal path.
◆ On the ledge, turn around and scan behind your arrival point for the container.
These steps are less about moving slowly and more about preventing repeated searches. If the supplies do not appear where expected, reassess your tower position and camera angle before leaving the area.
Rewards and Long-Term Value
Completion provides the yellow Radio Renegade outfit color, five Mechanical Components, and three Mod Components. The components make the mission worthwhile for players who are still building up crafting resources, while the outfit color is a smaller cosmetic incentive.
The more lasting benefit is familiarity with Spaceport. Once you know the western road, the bus location, the northern tower, and the climbable ledge, those spaces stop feeling like disconnected scenery. That knowledge can improve future movement even when no quest marker is pointing there.
For players looking up A Wrench in the Works Arc Raiders, the efficient answer is clear: inspect the bus behind the driver's seat, then use the scrap-metal path on the northernmost Water Tower and look back for the supplies. Bring a route plan, not just a destination, and consider cheap ARC Raiders Items only as a supplement to good map awareness. The quest is most useful when it teaches you how to search Spaceport, not merely where to stand once.
