Most gem grinds in Diablo 4 feel like background noise until you chase a Flawless Horadric Gem. Then the numbers get silly. With the right Escalation loop, though, Diablo 4 Items aren't the only shortcut; smart routing can turn a miserable evening into a focused farm.
Why the Third Floor Is the Real Prize
Escalation runs aren't about clearing every room once you have the loop live. Clear floors one and two normally, then slow down at the second portal choice. With Branching Pathways unlocked, you get three options and can steer the third floor toward a specific reserve plus Dark Omen. That pairing is the whole trick. You loot the third floor, leave before completion, and come back to refreshed chests and another ambush. Miss either affix and the run is still playable, just nowhere near as juicy.
  1. Finish the first floor quickly; its rewards don't decide whether the later reset is worth keeping.
  2. On floor two, choose the portal that gives your third floor the most useful reserve.
  3. Keep rolling sigils until Gem Reserve and Dark Omen land together; don't settle for generic gem bonuses.
Make Every Reset Count
Once that pair appears, stop treating the floor like a standard dungeon. Open every Horadric chest first, because targeted reserves scale far better than the vague Gem Reserve roll. At Torment 12, a good chest can throw out roughly 270,000 fragments for the gem you actually need. Dark Omen does the heavy lifting: its stalking boss can drop about 750,000 each time. Kill it, grab everything, then leave the end boss alive. The exit portal is bait. Taking it finishes the Escalation and ruins the repeatable third-floor state.
  • Open chests before chasing the ambush, since backtracking through cleared rooms wastes time and breaks your rhythm.
  • Prioritise Ruby, Amethyst, or your chosen reserve; the generic version pays noticeably less per chest.
  • Leave the end boss untouched and ignore the exit, even when the dungeon looks completely cleared.
Reset Without Throwing Away the Run
Resetting safely is where most players botch it. Teleport to town while still on floor three, then enter a nearby ordinary dungeon. Seer's Reach is a common pick because it helps remove the return portal from the Escalation. Don't clear it; that is dead time. Open the map, switch to Sanctuary, and teleport straight to the active Escalation marker. Chests should be back, and Dark Omen can stalk you again. If the portal hasn't reset, change the normal dungeon and test another nearby route. Keep Forgotten Souls and gold in mind too: fragments alone won't craft the finished gem.
  • Never kill the Escalation boss during a loop; completion is the one mistake that resets your progress.
  • Use a normal dungeon only as a portal breaker, then teleport out immediately rather than clearing it.
  • Bank enough Forgotten Souls and gold beforehand, because converting fragments through each gem tier isn't free.
Use the Window While It Is Open
Patch notes can change this overnight, so don't build your whole season around it. If the loop still works, buy cheap D4 items can cover gaps while you save your fragments for the craft. Either way, check the third-floor affixes before committing your time.
